2004 Ram 1500 Tire Pressure
Old Oct 31, 2020 | 10:21 AM
dukeofearl's Avatar
dukeofearl
Default 2004 Ram 1500 Tire Pressure
I just got a 2003 (sorry NOT 2004) Ram 1500 conversion van with a hi top roof and 5.2L v8. The door sticker is completely worn out and I can't see the recommended tire pressure. I searched this forum and couldn't find specific info for this model but seems like 35psi is recommended for similar vans?
Recommended tire size is 225/75/16 but it currently has 245/75/16. The tires are pretty worn so will probably replace soon with 225's. The van has a towing hitch but I don't plan to use it, maybe occasionally.
Thank you
Old Oct 31, 2020 | 11:12 AM
The label is pretty generic, and lists the 'standard' sized tires that came on the van. You can go here, and get a build sheet for your van, and that will tell you what size tires it had on it from the factory. (likely NOT 225's......) When you get new tires, the installer should know recommended pressure for them.
Old Oct 31, 2020 | 11:45 AM
dukeofearl's Avatar
dukeofearl
Thanks - that's interesting - the link you provided showed it as 245/75/16, but when I searched with this link, it shows 225/75/16
https://dodgeforum.com/forum/vindeco...WB11YX3K522615
Old Oct 31, 2020 | 11:51 AM
I would be more inclined to believe the link I posted, that's direct from Chrysler.....
