spare tire 2000 dodge ram 2500
Old Jan 29, 2021 | 06:22 PM
frank1182's Avatar
frank1182
Default spare tire 2000 dodge ram 2500
I am unable to locate lug to lower spare tire. I have looked under back bumper but to no avail. Any feedback would be greatly appreciated.
Old Jan 29, 2021 | 10:16 PM
Crawl under the van, and you should be able to see the tube that the crank should insert into, to lower the spare.
Old Jan 30, 2021 | 11:31 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Open the rear doors and you should see a hole above the back bumper. There might or might not be a plug covering the hole. Anyways, the jack crank rod goes in the hole to turn the wheel lowering mechanism.
I know this is a pickup truck video, but the operation is the same for the Vans. You can jump to about 1:55 to see what you need to see.
Old Feb 1, 2021 | 06:39 PM
Frank Rizzo's Avatar
Frank Rizzo
Originally Posted by heyyou
crawl under the van, and you should be able to see the tube that the crank should insert into, to lower the spare.
thank you very much i will try that
Old Feb 4, 2021 | 06:11 PM
volaredon's Avatar
volaredon
I've never seen a under mount spare on a Dodge full size van. The OP says it is a Dodge 2500 I am wondering if he is talking about a pickup? The gas tank is behind the axle on the vans, no spot for spare tire there.
Old Feb 5, 2021 | 06:31 AM
Busted Nuckles's Avatar
Busted Nuckles
My 1999 is under where he describes in the back and my gas tank behind the driver's seat. Alloro is correct.
