Transmission swap
Has anyone swapped the 518 OD trans in place of the 500 OD trans? I have a 1989 B250 with the 5.2, the 500 transmission is shot. I have a 518 that I've been kicking around for years. This seems like a good time to use it. I know it will bolt up. Just curious about drive shaft mods, wiring, and the such. Any info would be appreciated.
What year is the donor trans? If it's a 46RH, (3 pin trans connector) it should bolt right in, but, I think it is a bit longer than the 500...... so, may need to move the mount, and shorten the driveshaft.
See if this DIY page helps any.
Dodge 518 Conversion. 727 to 518 Transmission Swap Information. - PATC - TransmissionCenter.net
