1994 Dodge Ram B350
Old Apr 18, 2022 | 04:33 PM
lradams244's Avatar
lradams244
Default 1994 Dodge Ram B350
Hi, just joined today and need some advice. Have a 1994 dodge ram b350 that is not starting found a broken wire on the connector from the loom to the distributor, how best to fix it? it is a 3 pin male connector. Have been trying to find a connector at the local parts stores but no luck, is this a 12 or 10Awg wire? can someone point in the right direction.
Thanks
Leon
Old Apr 19, 2022 | 08:59 AM
Moving this to the Van section for ya.
You might be able to find wiring diagrams for you van here. As for fixing the wire, can you simply splice it back together?
Old Apr 19, 2022 | 04:13 PM
lradams244's Avatar
lradams244
Thanks, It broke just by the connector, I am checking if I can take out the pins from the connector.
Old Apr 19, 2022 | 07:18 PM
Need a special tool for those, but, they are available, and cheap.
