76 dodge B300 wiper/turn signal issues
Old May 22, 2022 | 10:09 AM
Burnttoast1980's Avatar
Burnttoast1980
Default 76 dodge B300 wiper/turn signal issues
Hey everyone, I have a 76 Dodge sportsman rv, the wipers and turn signals would just stop working randomly at the same time. If one doesn't work the other doesn't either, now both will not work at all. Wondering if it's a relay, or the moter, or a ground etc. Any ideas of ehere to start to find the issue. Thx James
Old May 22, 2022 | 11:55 AM
Busted Nuckles's Avatar
Busted Nuckles
Are both on the same switch?
Old May 22, 2022 | 01:21 PM
ol' grouch's Avatar
ol' grouch
It could be your switch but back then I think they were separate. With the age of the vehicle, it may be just your relays (flasher unit) going bad They are the old thermal relays and they just wear out. I'd slap a couple of new ones in and see what happens. If you go with solid state though, you'll have to check your bulbs from time to time. Solid state won't light up and stay lit when one is burned out like the thermal ones will.
Old May 22, 2022 | 05:18 PM
Burnttoast1980
Sounds like a start. Gonna give that a try, let you know how it goes. Thx
Old May 22, 2022 | 07:11 PM
ol' grouch's Avatar
ol' grouch
They are usually round things in or by the fuse block. Normally, they were round but I've seen square ones too. Make sure you get one with the same number of prongs. Now, they are mostly 3 prong but back then there were a lot of two prong units
