castle nut torque settings
Old Dec 6, 2022 | 03:12 PM
stephendumouchel's Avatar
stephendumouchel
Angry castle nut torque settings
When I torque the upper ball joint castle nut to specs. (55 to 60 ft lbs.) The cotter pin hole is way beneath the castle nut. And if I loosen the nut to engage the cotter pin it is way too loose. Whats up?
Old Dec 6, 2022 | 07:45 PM
Hole in the knuckle has expanded..... or, wrong ball joint.
Old Dec 7, 2022 | 03:47 PM
stephendumouchel
you were correct. wrong ball joint. What about the torque setting? Haynes says 135 ft lbs for the ball joint nut Does that sound right?
Old Dec 7, 2022 | 08:36 PM
Seems reasonable. You REALLY don't want those to come loose, or be sloppy.
