Drag link
Old Mar 24, 2023 | 01:39 PM
sealow's Avatar
sealow
Default Drag link
1996 dodge ram van 2500: Question: could I replace the tie rods on the drag link?
Thank you
Old Mar 24, 2023 | 08:01 PM
Yeah, they should just bolt on. Getting 'em off is the fun part. You will need an alignment when you are done.
Old Mar 24, 2023 | 10:03 PM
sealow's Avatar
sealow
thank you, Sir.
Old Mar 25, 2023 | 10:49 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Like with replacing any front end part, once you crack it loose you count the number of turns to remove the tie rod. Thread the new tie rod in the same number of turns and your alignment will be at lease good enough to drive.
