Blower motor resistor, hot plug & wires.
Old Aug 3, 2023 | 11:24 AM
97St.Wagon3500's Avatar
97St.Wagon3500
Default Blower motor resistor, hot plug & wires.
Title says it all. Just got done with changing my ac evaporator, Heater core, acc/dryer. Well upon re installing everything, I noticed the plastic end that plugs into my blower motor resistor has 1 terminal that's somewhat melted and discolored. What would be the best course of action to take here? I also ran the fan on high and noticed while running that terminal and wire gets hot still. Should I consider connections being cleaned? New resistor? Replace the wiring and clip? Thanks in advance for tips and help!
Old Aug 3, 2023 | 12:33 PM
Start with cleaning all the connections, and making sure the ground is good as well. (not sure where the ground actually is for a it all though.....) Might pull the resistor, and see what things look like. If its burnt, yeah, replace it.
