Weird event with my van.
Old Aug 25, 2023 | 09:48 PM
  #21
ol' grouch's Avatar
ol' grouch
Originally Posted by jeffersonracing
Decided to make a fairly short trip to pick up some AMSOIL, but didn't make it. Same scenario. Swapped the relays which didn't change anything. He picked me up and got the oil and we talked for a while to let it cool off. Went back and the van was gone. Police had it towed. Big bummer, but at least it wasn't towed by some theft ring. While I was waiting I saw a cop go by and never even paid any attention to me. Then barney fife went by and had it towed. The tow bill is $100 higher than when I had it towed a longer distance the other night. Quite a money making operation they have going on.
I'm just wondering if the CNG to gas conversion was done sloppy. Over the years, I've seen grounding issues cause intermittent problems. I'd go over the grounds. Both ends of each ground. I've seen cables that looked good at the top but at the other end be corroded. This includes the regular heavy ground cable, the cable that goes from the fender to the - terminal as well as the ground straps from the firewall to the engine.
Does it only fail when the van is hot? Any codes in the computer?
Old Aug 25, 2023 | 09:59 PM
  #22
jeffersonracing's Avatar
jeffersonracing
No lights are lit, but I haven't checked. I kind of figured if there was a code the check engine light would be lit up. So far it has only done it when it's hot. As far as the conversion that was done there hasn't been any issues with the van until now. It's going to be much cooler tomorrow morning so I'm hoping to make it home from the tow lot.
Old Aug 25, 2023 | 10:08 PM
  #23
ol' grouch's Avatar
ol' grouch
I had a thought. (Really!) What year is this van? A failing brain box on an OBD I system will do this. Those go bad so rarely, they get forgotten. If your van is a 1995 or earlier, that may be the issue. You can check for codes by doing the key dance. Do NOT hit the starter, but turn the ignition to on, then off, then on, then off and then on and leave it on the third time. This works on OBD I and OBD II. Either your check engine light will start flashing or the codes will appear in the odometer.
Old Aug 25, 2023 | 10:45 PM
  #24
jeffersonracing
It's a 96. I have a code reader. I can check for codes when I get it home.
Old Aug 26, 2023 | 10:28 AM
  #25
ol' grouch's Avatar
ol' grouch
Darn, that was when Chrysler went to OBD II. You may have a transitional unit being a government purchase. If you have the OBD I engine controller, it may be bad.
https://www.ebay.com/itm/22570872971...Bk9SR4bQuKPGYg
If you have OBD II.you won't have that but you will have a crank or cam position sensor. When those fail, they usually won't set a code because they just quit sending a signal. The computer doesn't know it's supposed to be getting one so it doesn't set a code.
Either way, they can both cause problems under a heat soak condition.
Old Aug 26, 2023 | 06:28 PM
  #26
jeffersonracing
Got the van out of the police impound lot this morning and got to a block from the house before it died. Temp was in the 70's rather than the 90's. I have a code reader in the van that I have used not that long ago and it worked. All I got out of it was error. The pump would not run when turning the ignition on. Pulled it on home and let it sit. Went up a little bit ago and she fired right up. Code reader still read error. The fuel pump is now running when the ignition is turned on so the issue appears to be the fuel pump not running and killing the engine. Does the ecu have any control over the fuel pump?
I need to put the crossways tank support on that I picked up at pick and pull as I guess that didn't get done during the conversion. Would be a good time to put a new pump in. Is there any way for the rollover fuel pump killer circuit to act up and cause this? I hate to put a fuel pump in if it's actually something that is causing it to shut off.
Old Aug 27, 2023 | 07:32 AM
  #27
ol' grouch's Avatar
ol' grouch
I'm afraid I'm not computer savvy. It could be the ecm, others will know more than me. However, just because the temperature is in the 70's, doesn't mean the underhood is. If you have a hair line crack in a circuit part, like a cam or crank sensor, when it gets hot, the crack can expand and open the circuit.
Old Aug 27, 2023 | 09:03 AM
  #28
Yep. Computer controls the fuel pump. Next time it dies, need to see if you are missing spark as well.
Old Aug 27, 2023 | 11:56 AM
  #29
jeffersonracing
Yeah, I got out the manual last night and saw that the ecu controls the ground to the asd relay which cuts everything. It seems more logical it would be the ecu rather than the fuel pump. The really hard part is I'm not sure I can get it to do it here running in the driveway and that means another tow bill to get it off the road and back home to check things. I think it would be possible to ground the pin on the asd relay to see if that's the issue.
Old Aug 27, 2023 | 11:58 AM
  #30
Throw some tools in it, and go for a back-road cruise. Have the doghouse already removed... Drive till it dies, troubleshoot from there.
