Sealer needed on exhaust studs 5.2 v8
Old Nov 20, 2023 | 06:18 PM
1996 B2500's Avatar
1996 B2500
Default Sealer needed on exhaust studs 5.2 v8
I had to replace 3 of the 4 exhaust studs on the 5.2 in my 1998 B1500. After I screwed the new ones in and put the heads back on the engine, I read in my manual, it said that sealer should be put on the threads that screw into the head. The stud holes are blind holes that don't go into a water jacket, so do I need to remove those studs and put sealer on those stud threads??? None of the bolt holes go into water passages.
Old Nov 20, 2023 | 06:53 PM
If they don't leak water when its up to temp, and cooling system is pressurized, I wouldn't worry about it.
Old Nov 21, 2023 | 09:03 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
If the holes don't penetrate into a water jacket, then there's no need for sealant on the threads.
