1998 B1500 hard starting when cold
Old Dec 9, 2023 | 03:20 PM
1996 B2500's Avatar
1996 B2500
I cycled the key on/off 5 times then attempted starting. It then fired right up. Sounds like pressure regulator getting weak.
Old Dec 13, 2023 | 07:24 PM
1996 B2500's Avatar
1996 B2500
I will be replacing the pressure regulator this weekend, will report my findings afterward
Old Dec 19, 2023 | 07:21 PM
1996 B2500's Avatar
1996 B2500
Well, here's an update: I was looking at the gas gauge, and it was reading 1/8 tank, after the road testing and idling I was doing. So I went and put 10 gallons of fresh dino juice, it brought the gauge to just over 1/2 tank. Then I made a start attempt, this time it fired right off. So, apparently, it being at 1/8 tank, and parked on a slight incline the fuel level was apparently low enough that it was having a hard time priming when I turned on the key
On a side note, is E-15 (88 octane) safe to use in my 1998 5.2?
Old Dec 20, 2023 | 07:01 AM
Probably not. The engine is rated to burn gas with up to 10% ethanol. It *might* work, but, expect power and fuel mileage to suffer.
