2000 Ram Van 1500 'Bucking' at 40mph with gas
Old Dec 23, 2023 | 12:40 PM
FatMouse's Avatar
FatMouse
Default 2000 Ram Van 1500 'Bucking' at 40mph with gas
Hi everyone,
I just picked up a 2000 Ram Van 1500 with 200k miles for cheap. Transmission was rebuilt at 190k. Front control arm was replaced right before I bought it. Starting to work through the issues and here's today's symptom...
At 40mph, the rear end feels like it's bucking or kicking around. The sound is a fast, deep dull thumping, probably 3 or 4 beats per second. Sensation is like the back end is bouncing up and down or kicking forward and backwards. This is ONLY when I'm giving it gas. When I take my foot off the pedal or shift into neutral, the sound and sensation disappear immediately. Give it a little bit of gas again and the bucking returns. Below 35mph, it's smooth as silk.
Tires are Trail Guide HLTs and look fairly new.
Any obvious culprits, or places to start looking? Really appreciate any guidance y'all can provide.
Old Dec 23, 2023 | 07:15 PM
Try hitting the O/D off button on the end of the shifter while its doing that, does it stop?
Old Dec 24, 2023 | 10:33 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Driveshaft U-joints could be worn.
Old Dec 26, 2023 | 11:30 AM
FatMouse's Avatar
FatMouse
Thanks for the help, HeyYou! And merry Christmas!
I tried turning off OD this morning and the hammering stopped immediately. Turn OD back on and it immediately returns. What's this mean??
Old Dec 26, 2023 | 11:34 AM
FatMouse's Avatar
FatMouse
Hey Alloro - There were three of the + shaped universal joints in the back seat when I bought it. Are those something you can get in without a lift?
Old Dec 26, 2023 | 02:38 PM
Most likely its an engine misfire. When is the last time it had a tune up?? Plugs, wires, cap rotor?
Old Dec 27, 2023 | 08:37 AM
alloro's Avatar
alloro
New or used? If they're new, then the previous owner probably knew they needed to be replaced. Replacing them requires removing the driveshaft and having access to a press. If they are used, then they've likely been replaced.
Old Dec 29, 2023 | 05:09 PM
FatMouse's Avatar
FatMouse
Replaced spark plugs, wires, cap and rotor yesterday. Initial test drive feels noticeably better. Passed through the 40mph without feeling the original kicking feeling. Thanks again!
Old Dec 29, 2023 | 07:13 PM
Don't forget the air filter.
If you have more than like 150K miles on it, O2 sensors wouldn't hurt either.
Here, let me spend some more of your money.
Old Dec 30, 2023 | 04:35 AM
Moparite's Avatar
Moparite
Don't forget the plenum gasket fix!
http://www.hughesengines.com/Index/p...p?partid=27091
