speedometer reads slow
Old Mar 30, 2024 | 01:40 PM
ourvan's Avatar
ourvan
Default speedometer reads slow
1995 b2500 318 4 speed auto. Speedo is showing 5 / 7 mph slow. I changed the 3 wire sender in the tailshaft. No improvement. Some mornings it will only show 20 mph for the first 5 to 10 miles. The odometer seems to be showing ok.
Any ideas?
Thank you.
Old Mar 30, 2024 | 03:41 PM
Maybe pull the cluster, and go after the works for the speedo with some graphite lube... (dry lube of some description.)
Old Mar 31, 2024 | 01:42 PM
ourvan's Avatar
ourvan
The speedo is electric not cable driven.
Thank you for your reply.
Old Mar 31, 2024 | 06:38 PM
It is told what to display by an electronic signal, yes, but, there is still a mechanical movement in there. Given the age, might be just a bit sticky.
