1999 dodge ram 2500 van wipers died
Hello! New here.
Wiper motor and washer died.
TRIED:
*Jump 12v directly to motor. It works
*Jump 12v directly to washer, it works
*Jump motor body directly to batt ground, it does not work.
* new wiper/turn signal multi switch. Does not work
*replace "intermittent module" (above glove box). Does not work.
* I found a schematic showing an "Integrated Electronic Module" Supposed to be "Left side of the dash". I can't find this. Ready to just wire a toggle switch directly. Any help would be Greatly appreciated!
* Hooked up my scanner and it is giving me engine data in real time. When I switch it over to "Body", it says "No Communication", and asks if the key is on.
TRIED:
Central Timer Module, my resources says left center dash support.....
But, if you have the controller on top of the glove box, that is the 'standard' wiper system, and doesn't go thru the CTM at all.
