obd has power but scanners won't connect
Hi all tried to find answers via search but typical stuff like checking fuses and connectors haven't works.
I tighten up all the connections at the obd2 port and the scanner powers on, ignition turned on or running and it won't connect. Tried a scanner that works fine on my other vehicle.
It's a 1997 b3500 with the 5.9l. seems to be running fine but threw a code today and I can't read it. Any ideas?
It's just some cheapo scanner from Amazon but the one at AutoZone didn't work either and I've used that on older cars
I'm not really sure what to check but I disconnected the harness pulled each wire from the harness tightened up the connector and put back in and no dice
Key Dance: Have a paper and pen ready to write down the codes. Start with the ignition off. Within five seconds, switch the key on, off, on, off, on. (On not Start!)
The check engine light (CEL) will flash. Count the flashes Each code is a two-digit code, so a (for example) 23 would be FLASH FLASH (pause) FLASH FLASH FLASH (long pause) It will never flash more than 9 times, watch for pauses!
55 is end of codes - it's normal, and 33 is normal on earlier models if you don't have air conditioning.
