318 to 360 engine swap
Old 05-03-2024, 07:25 PM
Dodge01hgm's Avatar
Dodge01hgm
Dodge01hgm is offline
Default 318 to 360 engine swap
2001 ram van 5.2 - will a repower to a 360 block attached to a 46RE Trans? Has anyone done this swap. Any info would be great.
Old 05-03-2024, 08:58 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,224 Likes on 2,974 Posts
Need the correct flexplate for the 360, and it'll bolt right in, and hook right up. Get the PCM flashed for the larger motor, and you are all set.
Old 05-03-2024, 09:11 PM
Dodge01hgm's Avatar
Dodge01hgm
do you think MPG will be better or worse? van is mostly driven on highway
Old 05-03-2024, 09:20 PM
You may not even notice the difference. At most, you will probably lose a point, but, that's about it. If the 5.2 is really tired, you might even get BETTER gas mileage with the 5.9.....
Old 05-04-2024, 08:51 AM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Dodge Forum Moderator
The 5.2(318) is an internally balanced engine, while the 5.9(360) is an externally balanced one. Both will bolt up the same. You will however need a torque converter for a 360 because it has the external counterweight welded to it, the one for the 318 does not. Without the correct TC the engine will feel like it's shaking itself apart and will also trash the rear main bearing.
Old 05-04-2024, 09:37 AM
Dodge01hgm's Avatar
Dodge01hgm
ok, so I need a TC and a flex plate and a pcm flash, and everything will work as designed?
Old 05-04-2024, 10:38 AM
It was my understanding that the balance weights moved to the flexplate in 96, with the advent of OBDII..... Did the vans not do so as well?
Old 05-05-2024, 09:29 AM
alloro's Avatar
alloro
alloro is offline
Could be, my information was from doing swaps back in the 70s and 80s.
Old 05-05-2024, 11:17 AM
Dodge01hgm's Avatar
Dodge01hgm
I listing stated 2001, not 70's 80's
Quick Reply: 318 to 360 engine swap
