brake light swtich on pedal
Old May 19, 2024 | 11:24 AM
ElkCon's Avatar
ElkCon
Default brake light swtich on pedal
Hi all.
I am almost done installing a brake controller...the last step is to tap into tan/white for the brake activation.
So, I am a little older and a little bigger, so being under the column is a real pain in the butt.
I thought I was taking off the harness on the switch (I was doing this by feel) and the whole switch came out.
I didnt break it and nothing is damaged at all, but HOW DOES IT MOUNT back up there? I cant really see under there, so I am doing this all by feel.
Does it just slide on a bracket up there? It felt like it came out like a wiring harness would...it just came out....
Thanks - Im almost done
Old May 19, 2024 | 04:01 PM
ElkCon's Avatar
ElkCon
so i figured it out...there is a bracket that the switch goes into...there is flange that is on the switch...you insert the brake switch plunger side into the bracket..then turn it to the right and it is in...
this video at 1:55 and on shows it...it is the same as this grand caravan...
yea - my brake controller project is complete and working!!
if you have any ?s about this project just ask me!
