P0123 code....
P0123 code....
1999 ram van 3500 5.9
So I was driving and lost all throttle response. It threw a P0123 code so naturally I changed the TPS and still having the same problems. The symptoms are a VERY rough idle, almost sputter out and dying and some backfiring whenever I lose the throttle response while on gear. The only code I'm getting is P0123 and my mechanic checked the voltage to the new sensor. It ranges from 0.9-3.4 from idle to under load. I'm at a loss....any ideas appreciated
Readings should range from .45 volts at idle to about 4.5 at wide-open throttle. A P0123 trouble code means that the PCM has recorded a reading from the TPS that exceeds the normal 4.5 volts for more than two seconds. A fault like this means that the sensor either has a short or has failed.
