Pinout for PCM connectors (Halp.)
Old Jul 24, 2024 | 05:37 AM
nvnn's Avatar
nvnn
Default Pinout for PCM connectors (Halp.)
Rainbow spaghetti!!! Yayyyy
2000 B1500 cargo shorty with a 5.2L/ 318cc.
So I was changing out my faulty PCM and in so doing connector #1 fell apart on me…
basically building it from one I found at the local yard, but I only have a FSM for the 2000 Ram trucks. Nearly identical, but only nearly.
And the previous owner did some mix and match that I can’t even get into right now as it’s 3am and I need this van tomorrow for work… currently in a gas station (work van, so I have all my tools, luckily).
Truck FSM has fused B+ as RD/WT (don’t have) at 13, 13 is plugged.
Van connector has 22 24 25 open and DG/BK, BK/DG, BK/YL left over…
also I believe OR is 5v reference supply, correct?
on the truck OR is PTO switch which obviously don’t have, and the 5v reference is at 17.
3:28am and I’m praying there’s a wire wizard that can’t sleep rn…
THANK YOU!!!
Old Jul 24, 2024 | 06:17 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Did you get it figured out, or are you still stuck at the gas station?
Old Jul 24, 2024 | 01:30 PM
nvnn's Avatar
nvnn
It still there. Heading there now. Still need pin out for PCM connector#1 for 5.2 B-1500.
Old Jul 24, 2024 | 09:35 PM
Try here.
Old Jul 25, 2024 | 07:39 AM
alloro's Avatar
alloro
Here are all 3 PCM connector pinouts, right out of my 2000 FSM.
Old Jul 25, 2024 | 07:47 AM
alloro's Avatar
alloro
Just in case you need them, here is the circuit information description, and color code chart.
