Codes 15 & 37 1990
Old Oct 11, 2024 | 06:37 PM
misfit619's Avatar
misfit619
Default Codes 15 & 37 1990 B350 5.9L
1990 B350 5.9L extended is running fine, but I'm contemplating a longer trip in it and checked the diagnostic codes to see if there was anything to look at. I've been reading up on here a bit and found these explanations for the codes.
# 15 - No VSS signal (vehicle speed sensor ] / NO signal during road load conditions
# 37 PTU [ part thottle unlock] / open or short in control circiut solenoid [ A999 or A500 trannys only]
I am absolutely not a mechanic, but think I'd like to start taking on some of these with the old beast, so can anyone give me what and where you'd start on this? I believe someone in one thread suggested that the 37 might be erroneous, because some of these vans don't have the part it's assessing. ??? I think I've seen that on 15 there might be two speed sensors and that chasing the wire is probably a good idea.
Anything you can offer a newbie novice with as much specificity as you can is hugely appreciated.
Thanks.
Last edited by misfit619; Oct 11, 2024 at 06:59 PM. Reason: posted accidentally before done.
Old Oct 11, 2024 | 09:27 PM
Does your speedometer work?? If it does, it's just a wiring problem, (or a bad PCM....) VSS is in the tailshaft of the trans, and I believe the signal wire just splits off and feed PCM, and Speedo.
I assume the 37 relates to torque converter clutch. Is yours actually locking?
Old Oct 12, 2024 | 11:57 AM
Moparite's Avatar
Moparite
37 has different meanings depending on the vehicle, The lock up solenoid issue is correct for yours. I would fix the speed sensor issue clear codes and see if the 37 comes back. The pcm may be confused not seeing the speed.
Old Oct 12, 2024 | 01:41 PM
misfit619's Avatar
misfit619
yes, the speedometer works, so do i try to chase the wire and look for breaks? or do i need a new tool to assess?
no idea on torque converter clutch looking. it drives fine, i went from surface streets to highway, topping out about 70mph, without noticing anything out of sorts. i think my earlier comment about the 37 always being on on some of these vans was due to someone on here suggesting that i might not have a locking torque converter.
Old Oct 12, 2024 | 01:43 PM
misfit619's Avatar
misfit619
that sounds like a good start. i'm gonna be a little busy, so it might take me a few days to report back, but i will, probably looking for help with next steps. thanks.
