Horn
Old Nov 15, 2024 | 12:41 AM
rouge5's Avatar
rouge5
Question Horn
Are there wrecking yards that specialize Dodge B250 Ram van part??....need to replace the horn switch in the steering wheel
Thanks
Old Nov 15, 2024 | 07:26 AM
Many yards have websites that will allow you to go in and select specific vehicles to see if there are any one the lot. For example, Pullapart.C.O.M.
Old Nov 15, 2024 | 03:09 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Another website to check is: Car-Part.com--Used Auto Parts Market
Some of those on the website will ship to you, if you're too far away.
Old Nov 15, 2024 | 04:37 PM
rouge5's Avatar
rouge5
TY I'll check them, wonder how can find the part number for the horn ring what years compatible
Old Nov 16, 2024 | 08:17 AM
Horns are horns. Yes they can match why you need.
Old Nov 17, 2024 | 10:47 AM
ol' grouch's Avatar
ol' grouch
Thanks
Unlike trim and style, horns don't sell cars. Look for a similar year pickup truck. They often used the same hardware. It might look a little different, but will work. For instance, GM cars and trucks with crank windows all used the same design mount for window crank handles. Even earlier Cadillac's (early 1960's and earlier) used the same handles.
Old Nov 18, 2024 | 03:17 PM
rholmboe's Avatar
rholmboe
Thanks
Hi,
my 84 B250 horn wasn't working when I purchased it three years ago.
My mechanic said re doing the wiring was a nightmare and was not worth the effort. So, I found the only easy inexpensive way was to
take it to an vehicle electrical specialist and had him install a spring loaded push button switch in the metal dash.
Easy to get at and works just fine. I rarely use the horn anyway.
Good Luck and Cheers.. RH
Old Nov 26, 2024 | 06:30 PM
rouge5's Avatar
rouge5
Default Removal
Is there video or direction removal of the horn brush????
[img alt="how to remove horn brush
"]https://cimg9.ibsrv.net/gimg/dodgeforum.com-vbulletin/2000x1504/b250_665d7d6df159499e14c85451df85d91971125016.jpg[/img]
