Extended Van Rear Weight Placement
Old Nov 21, 2024 | 09:58 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by Brimike
Alloro,
When you say havoc, do you mean constantly havoc, like i will need to get re-aligned all the time, or just initially to account for the weight reduction (or weight lift i guess) on the front axle.
Adding that much weight behind the rear axle will cause the front to lift a bit. When the front lifts, the wheel alignment changes and your tires will wear unevenly. Once the rear weight is removed, the front end will go back into alignment.
Old Nov 25, 2024 | 09:44 PM
ol' grouch's Avatar
ol' grouch
600 pounds will put a strain on the metal of your frame. You'll need to beef up the mounts. Yes, it will mess with your steering too. While alignment can be a problem, I'd be more concerned with handling in the rain and snow. Get your self a trailer big enough to haul the bike and maybe a little more. Possibly some racks for fuel and such.
I swap cars like some people swap comfy shoes. I currently have 4 plus a bike. I've had my 5X10 tilt bed for 30+ years as it's just so handy to have. Newer ones have a ramp built in. Mines a tilt bed with a hand winch I added to pull tings onto it. Get one a little bigger and you'll use it a lot.
