B2500 No Bus problem year 1999
Hello I have the following problem
When i start my Van the gauges come up, and at a sertain point to go back to zero, and then it says No-Bus.
It keeps running no problem
Alternator also does not charge
Placed a new one already
What can couse this problem
Thanks in advance
Thanks in advance
That message indicates a loss of communication between the instrument cluster and the PCM. Either of those could be going bad or simply unplugging the PCM connectors and then reinserting them might solve the issue.
All of your gauges are driven off of the communications bus, if there is no bus, then there is no information for the cluster to display...... If the truck runs, then, at least part of that bus is working, and the problem is between the cluster, and PCM.
