Adjust Brake Pedal Height
Old Feb 24, 2025 | 09:32 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by arty4444
kicking them with his feet and rapping pretty good with a small hand sledge.
There just the slightest drag I feel right at the end when forward motion stops.
I did it myself and with a pretty decent shove the wheel would only spin about 1 full turn. He said that was normal- is it?
The brakes sound a bit tight, but they will wear in pretty quick and as long as there isn't any heat buildup you're safe.
For the front wheels, the calipers are holding the pads to the rotors and cause a mild drag...this is normal. It is why the wheels don't spin easily.
Old Feb 24, 2025 | 10:04 AM
arty4444's Avatar
arty4444
Thank you alloro.
Peace of mind can not be over rated.
