I have a 94 dodge Jayce conversion van, that is having problems starting all of the sudden. has run great the last 2 years I’ve owned it but recently takes several times to start and pressing heavily on the gas pedal. Once started runs like a top with zero problems. I’ve seen ignition coil and fuel filter as a likely cause of this issue. Anyone have any experience with this, main experience has been Chevy and fords this is the first dodge I’ve owned. Thank you for any help/suggestions provided. 5.2l v8
Not sure about the year of van but sounds like TPS/IAC. Had similar problem, worked fine once its warmed up a bit.
You can easily remove and clean them.
