86 dodge b350 van igntion switch install?
Old Aug 11, 2025 | 09:18 PM
Bigblockbryan1982's Avatar
Bigblockbryan1982
Default 86 dodge b350 van igntion switch install?
So I'm trying re install igntion switch on 86 b350 on bottom of column.Probelm I have is with rod hooked in I can not bolt switch back on holes will not line up.
I have put the igntion in accerory on column and only thing i didn't do was lower column since enough room under dash.
Old Aug 13, 2025 | 09:12 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
What if you rotate the key? Doing so should move the rod and switch so the mounting hole can line up.
