When does your gas empty light come on?
Old Apr 2, 2026 | 03:28 PM
OregonApe's Avatar
OregonApe
Default When does your gas empty light come on?
According to my build sheet (2000 b1500) I have a 32 gallon tank but if I fill up when the empty light comes on it takes 24 gallons or so. Do I really have 8 gallons left when the empty light comes on? If so that would give me some comfort because that means even when towing I still probably have approximately 80 miles of range left.
Edit: I see the manual says it should come on at 1/8 left. That would be 4 gallons which has not been my experience. What could cause that?
Old Apr 2, 2026 | 05:58 PM
I have a 34 gallon tank in my truck, the light comes on at 1/8th of tank, but, the tank only takes about 26 gallons to full at that point, so, 8 gallon reserve..... Yep.
Keep in mind, the last gallon or so you won't be able to access..... So, don't push it too far.
Old Apr 2, 2026 | 06:03 PM
OregonApe's Avatar
OregonApe
So is it actually when the gauge shows 1/8th left it comes on but there is much more than 1/8 of a tank left?
Yeah, I've never run out of gas in my life, but knowing I have 8 gallons left when it comes on is a much bigger cushion than 4 with 3 actually usable.
Old Apr 2, 2026 | 09:08 PM
That's how mine works. I would guess the Vans are the same. I figure I have 50-60 miles left once the light comes on. I have never pushed it that far though.
Old Apr 3, 2026 | 10:54 AM
ElkCon's Avatar
ElkCon
yep...
and FWIW for the community...
I would say most if not almost all these vans have had replacement fuel pumps put in them. I have done it twice on my van (once because is was bad and then again as a suspect) and I have found that the gauge read different between all three pumps...
After a fill up:
The original would show 100 miles at 3/4 and then drop fast to 1/8 where it did the 6-8 gallons left reading
The second pump was pretty much 50 miles per 1/4 and did when empty still had 5+ gallons in it
My thrid pump now goes 100 miles at 7/8s of a tank, and then drops LINEAR from there...so 3/4 is 150,1/2 is 200, 1/4 is 250 and E is almost totally empty (300) I know over 300 Im pushing it because I get 12.x a gallon...11 on short trips
