cooked engine!
Pressure of sorts, many times it appears as a blueish white mist. If it's hard to see, hold a tissue over the hole and see if it blows a hole through it. Because of the PVC system, there is supposed to be a slight vacuum in the crankcase, so if you have any pressure, worn/cracked ring are high on the suspect list.
