Whining transmission
Old Jan 29, 2007 | 09:35 PM
Avenged's Avatar
Avenged
Default Whining transmission
I've got an 01 ram van 1500. When the transmission is in overdrive it whines. I changed the fluid and filter and it still does the same thing. Any suggestions?
Old Jan 30, 2007 | 12:52 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Default RE: Whining transmission
You're looking at an internal problem that going to require disassembly. The two most common causes for whine are worn gears orbearings.
Old Feb 24, 2007 | 01:06 PM
Avenged's Avatar
Avenged
I've now been told that itcould bethe torque converter. Does this sound right that it would only do it in overdrive? I don't want to buy a new torque converter and find out that that isn't the problem.
Old Feb 24, 2007 | 03:13 PM
alloro's Avatar
alloro
If it was the TC, the noise would be there for every gear and the pitch would follow engine speed since the TC is on the tranny input shaft. If the pitch follows vehicle speed, the problem is with the output end of the tranny. But more importantly, if you only get the pitch in OD then the problem is in the OD mechanics, which is of course at the tranny output.
Old Feb 28, 2007 | 03:08 AM
Avenged's Avatar
Avenged
Couldn't bethe lock-up?
Old Mar 7, 2007 | 08:33 PM
alloro's Avatar
alloro
Nope, nothing to do with lockup.
Old Jul 13, 2007 | 01:41 PM
Avenged's Avatar
Avenged
It also does it in 2ndjust not as loud. And it is more of a rubbing sound. The fluid is still clean looking but foamy after driving. Shifts normal still and no noise if its in drive.
Would I be better off looking for a good used transmission instead of trying to fix this one?
Old Jul 14, 2007 | 11:59 AM
alloro's Avatar
alloro
Foaming is a sign of an overfilled transmission because the moving parts are immersed in the fluid, similar to juice in a blender.
About $1500 for a rebuild and $500 for a used (plus the time or labor to do it), choose your poison.
Old Jul 14, 2007 | 10:24 PM
stev's Avatar
stev
PLUS, either way, make sure ATF+3 or ATF+4 is used to refill the tranny if your doing any work on it.
Old Jul 17, 2007 | 12:35 PM
Avenged's Avatar
Avenged
ORIGINAL: stev
What kind of damage will Dexron fluid cause?
