Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Biggest rubber to fit on stock 17's?
Old Apr 16, 2007 | 01:25 PM
hkspwrsche's Avatar
hkspwrsche
Default Biggest rubber to fit on stock 17's?
Since I'm lifted I'm curious what the largest tire I can put on the 17" wheel or is the only way to go aftermarket? I like the stockwheels actually.
Thanks
Harold
Old Apr 16, 2007 | 01:40 PM
hkspwrsche's Avatar
hkspwrsche
Default RE: Biggest rubber to fit on stock 17's?
I was searching and saw some 285's listed as close to 33's and some 16" wheels running 305's?
Old Apr 16, 2007 | 01:51 PM
crcarch's Avatar
crcarch
If you're using the stock wheels, then clearance shouldn't be a problem with whatever will fit on the rim. The most important thing IMO is the overall height. You want to keep it close to stock so that the speedo will stay correct and your gearing won't be affected.
Go to http://www.discounttiredirect.com/di...foTireMath.jspat Discount Tire and plug in your stock size. Plug in bigger size tires to find out which larger sizes have the same (or close) outside diameter. I try to keep the overall difference in speed shown at 65 mph to less than a 2 mph difference.
If the original is a 245/70R17, looks like a 285/60R17 would be perfect.
I went from the stock Goodyear275/70R20 to Yokohama Parada Spec-X 305/50R20's and they fit just fine, ride much better andlook awesome!
Old Apr 16, 2007 | 02:28 PM
hkspwrsche's Avatar
hkspwrsche
I believe the speedo has already been adjusted before I got it for 35" tires. It already has 456 gears also. SO I'm just trying to find sizes that would be around 35" I guess
Old Apr 16, 2007 | 02:31 PM
hkspwrsche's Avatar
hkspwrsche
Or 35" equavalent in metric for the 17" rim
Old May 10, 2007 | 12:57 AM
USA1Ram's Avatar
USA1Ram
I just replaced my 265's with 285's. The tires are about 1"+ taller and wider and I don't have any rub issues. Theydo 'balloon' slightly. My only dislike is that they float abitwhen I travel on the highway orunder harsh steering conditions.
