ok what size tire/rim combo?! 95 ram 4x4 6in lift
IVe been trying to get info on how to fill in the 6in lift on my 95 ram 4x4 with 6in of lift. I asked what the largest 17 I could get qwould be then if I can get 15" wheels to go to 35's but, I cant seem to get an answer. Anyone know what tire wheel combo to fill in the wheel wells a bit?!?
Thanks
Harold
Thanks
Harold
I have a 98 Ram 1500 4X4 with a 6" lift and a 3"body lift. I have a set of Pro Comp 17X9 8089 rims and a set of Dunlop Radial Mud Rovers 35X12.5R17. If you click on the pic enclosed and enlarge it you will get an idea of what this set up looks like. The truck originally came with 37's on a 15X10 rim but the tires were screwed up due to bad ball joints and the rims were very neglected. Hopefully this helps.
[IMG]local://upfiles/56056/F4349AA34E83456ABC183AF4036803AD.jpg[/IMG]
[IMG]local://upfiles/56056/7644B348CEE44987986071A2F7775E71.jpg[/IMG]
Will 35 1250 17's fit on my stock 17s or only on aftermarket wheels?My truck hasonly got 6in of lift total compared to your trucks 9in or lift.My stockwheels look like they have as much as your 35's
They should afterall they are only 12.5 wide. If you have any questions go to www.4wheelparts.com they have all the tech specs regarding wheel/tire sizes, gear ratios, etc. Also you can call them at 1-800-829-1253 ask for Leon at ext.5110 or Eric at ext. 5310 tell them Nicco sent you.
