Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
overdrive problem on 90 ram
Old Sep 9, 2004 | 11:10 AM
timsdodgeram's Avatar
timsdodgeram
Default overdrive problem on 90 ram
Help!!
My 90 ram has a 318 v8 with an automatic transmission. It has an electric switch on the dash for overdrive. the tranny shifts into overdrive at about 50mph and when i lift off the gas pedal at any speed above 50 it shifts back to 3rd. I adjusted the linkage but that didn't make a difference. what do I do to fix this.is there something on the tranny i can replace
Old Sep 9, 2004 | 11:58 AM
Snafu's Avatar
Snafu
Default RE: overdrive problem on 90 ram
Sounds more like your torque converter is unlocking, not your trans downshifting. If this is what's going on it's normal. I believe there's a way to wire a switch to the torque converter to manually lock it, but I'm not sure how exactly to do it. If your trans IS downshifting like you think, it's most likely a hydraulic problem inside. Is this a new thing, or has it always been this way? If it's new, have the trans flushed and put a new filter in it.
