Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
HEADLIGHT PROBLEM
Old Sep 14, 2004 | 08:43 PM
dralaska's Avatar
dralaska
Default HEADLIGHT PROBLEM
I have a headlight problem. It seems that I have water in the lens and it splashes up on the bulb and it blows out. I now have broken bulbs in the bottom of the lens. Is there a easy way or what is the way to remove the lens to clean it out and find the leak. Since I live in a Rain Forest in Southeast Alaska we get a lot of rain. If anyone can share the proper way to remove. Thanks, JOHN knjnf@uas.alaska.edu
Old Sep 14, 2004 | 10:08 PM
Beastmaker's Avatar
Beastmaker
Default RE: HEADLIGHT PROBLEM
Hmmm, seems like a simple fix. I'd drill small drain holes in the bottom of the headlight assy, to drain out the water. This would work as long as they are NOT seals assys, and are the modern plastic cases. Just a thought
