Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
How do you get the switch wires and switch inside the cab?
Old Jun 26, 2007 | 01:34 AM
nomadtraveler's Avatar
nomadtraveler
Default How do you get the switch wires and switch inside the cab?
I bought some driving lights and am at a loss on how to get the switch wires into the cab through the firewall. One suggestion was to run the wire through the door jam but that looks tacky and worry about a wire shorting out. Any Ideas? Thanks, Mark
Old Jun 26, 2007 | 02:51 AM
oefootball_70's Avatar
oefootball_70
Default RE: How do you get the switch wires and switch inside the cab?
I ran it through a spot where there is a little rubber insert, slid it right through it. It was on the driver side. I am guessing you have a 3rd gen, I do.
Old Jun 26, 2007 | 12:26 PM
rtmorrisjr's Avatar
rtmorrisjr
ORIGINAL: oefootball_70
I agree, all gen rams (actually every vehicle) have holes in the firewall for wires to get run through. Just look behind the dash for wires running throught the firewall and run them through there.
Old Jul 1, 2007 | 11:13 PM
Zzyzx313's Avatar
Zzyzx313
Check behind the driver side inner fender. Mine has a wiring harness there that runs into the cab.
Old Jul 17, 2007 | 01:32 PM
jeepking1's Avatar
jeepking1
As youre facing the firewall looking into the engine bay, just below and to the right of where the steering shaft goes thru the firewall, there is a cable running through a black rubber boot thing. I took a piece of sharpened coat hanger and poked it through from inside the cab out. Then I pushed my trailer brake wire through the hole into the cab. You can wrap your wires alongside the cable right on up under your dash. Mine is an '06 Mega cab by the way.
