Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Electric Brake Control
Old Aug 20, 2006 | 07:04 PM
rwl3's Avatar
rwl3
Default Electric Brake Control
I have an 06 Mega Cab that has the connector for brake controller under dash. Can someone tell me where to find the wire for the trailer brakes? All I have in the back is a 4 pin flat connector. I bought a plug/socket kit that mounts to the bumper perfect and plugs into the flat connector. The kit had 2 extra wires for aux. and brake but have found no wire to connect to for electric brake. Appreciate any help.
Thanks,
Ray
Old Aug 20, 2006 | 11:41 PM
DieselDemon's Avatar
DieselDemon
Default RE: Electric Brake Control
Your hitch doesn't have a 4 pin and a 7 pin right next to it? Has something been added, or modified?
Good luck.
Old Aug 21, 2006 | 02:15 AM
gtxpooch's Avatar
gtxpooch
If you have trailer/tow package on vehicle, you should have a blue connection next to the E brake. You should also have gotten the pigtail that hooks to the controller that plugs in in to that with your truck if bought brand new. Mine was in glove box and the directions are with it. The wires are marked what goes where.
Old Aug 21, 2006 | 07:50 PM
rwl3's Avatar
rwl3
I do have the blue connection under the dash. The truck was bought new and the window sticker states trailer tow wiring 4-pin. I have no pigtail in the dash. I did buy one over the weekend. My dad has a 1 ton and we installed a gooseneck hitch in his this past weekend and I noticed that his harness had the same 4 pin flat like mine but also an additional part of the harness branching off with a 7-pin connector going to the bumper. Since I have the blue connector under the dash, the brake control wire has to be going somewhere. I just can't find it anywhere.
Old Aug 22, 2006 | 12:45 AM
pcjeep's Avatar
pcjeep
If all you see by the hitch is the 4-way, you will need to have the Electronic brake wiring harness installed. It has the 7-way connector. the other end will plug into the connector under the dash
Old Jan 9, 2007 | 06:58 PM
grovesr's Avatar
grovesr
I have a 2004 SLT 1500 that also has just the 4 pin connector and I want to convert it to 7 pin to pull a trailer. Has anyone ever purchased/installed one of these?
Bob
Old Jul 17, 2007 | 02:42 PM
jeepking1's Avatar
jeepking1
I have an '06 Mega Cab, that had the factory 4 flat plug in the back. I bought from the dealer for $75 the 7 pin plug/harness assembly. It has the 7 pin plug that mounts on the back bumper w/ a wire that runs up inside the driver side tail light assembly if you wish to connect the lead for the backup lights. The factory 4 flat plug plugged into the new harness back at the bumper. The rest of the harness gets snaked up front where the red fused lead gets attached to the + battery terminal and the blue wire goes thru the firewall so it can be attached to the trailer brake controller. Ifound the little adapter to connect the trailer brake controller in a bag in the glove box. Note: While the wiring harness comes with instructions, they are picture instructions only with no written details.
Old Jul 17, 2007 | 02:49 PM
rtmorrisjr's Avatar
rtmorrisjr
you need the 7 pin for the trailer brakes to work
