Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Help!!! Blown fuze ?
Old Aug 10, 2007 | 08:35 AM
tiretread's Avatar
tiretread
Default Help!!! Blown fuze ?
Hey all, this is my first post and I'm sorry that it's a plea for help. I'm just about finished with my two weeks of vacation from the desert (currently deployed to Qatar) and I have an issue with my 01 Dodge Ram truck. Here's the issue:
I have no running lights and the dash/guage lights don't work. I have brake lights and blinkers but no lights inside the guages. Any ideas? I've checked all the fuzes on the left side of the drivers side and nothing is blown. I had this issue about 4 years ago and I remember just replacing a blown fuze.
Any help would be appreciated. I know that search is my friend but I'm ***** to the wall getting ready to head back to Qatar. Thanks guys!
Old Aug 10, 2007 | 09:15 PM
Dodge Tech's Avatar
Dodge Tech
Default RE: Help!!! Blown fuze ?
fuse F 20 amp outside and fuse 5 5 amp inside if they are both good then looks like a head light switch to me.
Old Aug 13, 2007 | 03:57 AM
tiretread's Avatar
tiretread
It's got to be the 20 amp fuze outside. Thanks!
Old Aug 13, 2007 | 08:40 AM
rtmorrisjr's Avatar
rtmorrisjr
hope its the fuse. that switch is like $75 and you have to have a security type driver to remove the screws holding it on. forgot how much and what size that was. if you find you need that info, post up and ill try to get it for ya.
Old Aug 13, 2007 | 11:24 AM
40intrepid's Avatar
40intrepid
Could also be the muti-function switch in the column.
My lights and wipers went wonky a few months ago, turned out to be the switch in the steering column.
$240 parts and labor at the dealer.[:@]
Old Aug 13, 2007 | 12:21 PM
rtmorrisjr's Avatar
rtmorrisjr
ORIGINAL: 40intrepid
thats the switch i was talking about. you can do it yourself for $75 (switch) and the bit needed to remove the screws (think like 5 bucks but not sure, it was cheap)
Old Aug 14, 2007 | 06:31 AM
tiretread's Avatar
tiretread
I'm hoping it's just the outside fuze. I'm back in Qatar already so this will have to wait until I get back. I have a feeling it's a fuze though. Same thing happened a couple years ago. The weird thing is that my trailer hitch harness was melting when the fuze went. I'm actually not sure if the harness caused the fuze to blow or vice versa. Guess I'll find out in 9 months! Thanks again for the info.
