Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
97 Ram 1500 trans Trouble
Old Aug 26, 2007 | 02:52 PM
Floydscatfarm's Avatar
Floydscatfarm
Default 97 Ram 1500 trans Trouble
I have a 97 Ram 1500 that is experiencing overdrive issues. The truck is a 2WD,has a 5.2 enginewith the electronic trans (46RE)and 145000 miles on it. When the truck is first started upand drivenup to about 10 miles, the trans works great. After 10 or so miles of drivingthe transmission begins to hesitate going into OD (4th). Usually after hesitating once or twice it will stop going into OD completely. After the truck sits and cools for a couple hours, it will go through the same process when you restart it. Other than this issue the trans works great. I have change the fluid and filter and also changed the throttle position sensor. Neither of thesetwofixeshelped at all. Has anybody else had a problem like this and found the answer? Thanks in advance for you help.
