Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Another new guy demanding answers and offering nothing in return
Old Sep 16, 2007 | 08:21 AM
bbourns's Avatar
bbourns
Default RE: Another new guy demanding answers and offering nothing in return
probably a bad u joint
Old Sep 23, 2007 | 09:00 PM
Cordoba man's Avatar
Cordoba man
Is it a gen 3 or 1 or 2? The live axle models have U-joints that click when they're pooched. The 3rd gen is CV joints. Different, but still a click. Just jack up the front end in neutral one tire at a time and turn the wheel by hand to see if that's it.
Probably just the outer joint.
Old Sep 26, 2007 | 12:56 AM
Barb's Avatar
Barb
From where you say the sound is occuring it sounds like it may be your gear box, check to see if it may be leaking down onto the idle control arm., if it is a second generation. Also on the second and first generation ram trucks you can easily look at your U-joints with a flash light and even fit your finger in there.
Old Oct 4, 2007 | 11:46 PM
nateblong's Avatar
nateblong
Its is the outer U joint, a cheap fix if you do it yourself.
