BIG RIMS
BIG RIMS
I have a 1996 dodge ram i currently have the stock 16 inch rims, i am wanting to put some 20 x 9 on it but im not sure if those rims are going to warp my brake disks, if so what can i do to fix it.
RE: BIG RIMS
Warped rotors are caused by overheating. The rims shouldn't adversely effect your rotors, since they aren't an integral part of the hub. If you've had problems with warped rotors in the past, upsizing the wheels may actually help because of increased air circulation around the brakes. Expect slightly longer braking distances, however, if the new wheel/tire combo is significantly heavy than stock. The heavier the combo, the more kinetic energy your brakes have to deal with.
RE: BIG RIMS
it isnt gonna warp your brakes.. it would actually allow them to breathe better and keep cooler... the downside is it will still be harder to stop that bigger rim...
