Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
water pump
Old May 6, 2008 | 07:55 PM
dodds dodge's Avatar
dodds dodge
Default water pump
How do you remove the cutch fan? I've been try with no luck any suggestions.
Old May 9, 2008 | 10:59 PM
Gone Campin's Avatar
Gone Campin
Default RE: water pump
rent tools specific for that purpose from an auto parts store. it holds the fan/clutch from moving as you break the bolt loose.
Old May 13, 2008 | 07:47 AM
steve05ram360's Avatar
steve05ram360
welcome to DF... another suggestion is a strap wrench on the pulley...
Old May 17, 2008 | 07:28 AM
timsalas's Avatar
timsalas
Meh tools DO NOT work, I bought em, and it was a waste of my money... if u need to replace the water pump, then I suggest Jamming a plier in the back so that the pully doesnt move then use a nice big adjustable wrench
This is what I used on the nut.. after 2 weeks of trying to take that sucker off I bought the wrench below, and took it off in 1 minute flat! Just be sure to jab the pully good so it doesnt turn..
http://www.harborfreight.com/cpi/cta...emnumber=39621
Old May 17, 2008 | 07:29 AM
timsalas's Avatar
timsalas
Oh and mine u had to turn counter clock-wise (if your standing in the front looking at the tail of the truck)
Old May 17, 2008 | 08:41 AM
dhvaughan's Avatar
dhvaughan
this response is a little late, but if the fan won't come off, just unbolt the water pump, cut the bypass hose, and pull the water pump, fan, and shround out all at once. then its easy to clamp the wp in a vise and remove it with a big adjustable or channel lock.
Old May 20, 2008 | 08:56 PM
RamItOne's Avatar
RamItOne
channel locks and pliers and ***** will knock it off.
