Gas Guzzler
Gas Guzzler
aftermarket air filter: volant, k&n etc, magnaflow cat back and then when that is done go here: http://www.kennebell.net/accessories...ptimizer2. htm </P>
keep in mind that any mileage increases depend largely on how you use your right foot but with these mods you should see abit of anincrease. Whether it is worth the expense (probably not) is up to you after all these trucksare not toyota prius' or four banger tacomas...you have a six thousand pound truck with the aerodynamics of a three bedroom house.</P><edited><editID>nuckingfuts</editID><editDate>38021.9399537037</editDate></edited>
Gas Guzzler
oh and coolio if you aren't using synthetic fluidsI would recommend you do so....it will help a bit...and to make ya feel a little better my '99 2500 with the 360 gives me about 9mpg, of course it hauls around about 1000lbs in the back every day <IMG src=smileys/smiley4.gif border="0"><edited><editID>nuckingfuts</editID><editDate>38022.5922106481</editDate></edited>
