Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
94 1500 won't lock the front axle for 4X4
Old Oct 27, 2009 | 08:45 AM
mwendig's Avatar
mwendig
Default 94 1500 won't lock the front axle for 4X4
My 1994 Dodge Ram 1500 4X4 5.2 L quit locking the front axle. I had this problem 12 months ago and I replaced the actuator, it worked fine from there on out. Now it quit again. I checked the vaccum lines and they have suction and switch properly, I don't have a gauage to check how much, how much pressure should I feel? If I take it off and hook it up the fork moves correctly so I guess it doesn't have enough power to lock the axle?
So questions is?
Pressure or actuator?
Old Oct 28, 2009 | 09:13 AM
mwendig's Avatar
mwendig
I got a vaccumm tester and tested both sides. They switch properly and get 18" each. Is this enough?
Old Oct 28, 2009 | 09:18 AM
95RAM360's Avatar
95RAM360
you should get the posi-lok from summit. it will lock it everytime. and its $202 i believe. but then you wont have to worry about it again
