Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
newbie question 'bout overdrive
Old Nov 16, 2009 | 09:29 PM
grnxrymnky's Avatar
grnxrymnky
Default newbie question 'bout overdrive
new to the forum and to dodge trucks...and 3/4 tons especially. long question short--when do i need to be in drive vs overdrive. i have big truck exp. (10 wheeler) and 1/2 ton exp but no 3/4 ton. my 2000 ram 2500 5.9 gas seems to be a real hoss but whenever i'm pulling a trailer when do i keep it in od vs d?
thanks in advance.............jim
Old Nov 17, 2009 | 01:32 AM
tlawre87's Avatar
tlawre87
That is really going to depend on the load. If your on hills def keep it in drive. The constant shifting is bad and you'll overheat the tranny. If you are running flat surface and its okay to put it into od, assuming your not pulling 8000lbs. If its heavy keep it in drive.
Old Nov 18, 2009 | 01:46 PM
95RAM360's Avatar
95RAM360
usually i have O/D off when driving city, and O/D on when driving highway
