Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
1 ton spring swap?
Old Apr 25, 2005 | 10:59 AM
4DrMopar's Avatar
4DrMopar
Default 1 ton spring swap?
Ok, sooo whats the scoop with taking a 1500 (like mine) and adding 3/4 or 1 ton springs up front? 2" and Desiels are 3"? That all there is to it?and If I wanna keep some of the rake to teh truck, a 2" block for teh back with the 3" springs? what about shocks, upfront,jsut order 3/4 ton shocks?
Old Apr 25, 2005 | 12:22 PM
Snafu's Avatar
Snafu
Default RE: 1 ton spring swap?
3/4 & 1 ton gas engine springs will get about 2-1/2", diesel engine springs will get about 3". You will need 3/4 ton shocks all the way around. And I'd suggest an add-a-leaf kit instead of a block in the rear. It's much more stable and only slightly more expensive.
Your other option is to get a 2" coil spacer kit from the guys at www.jeeperzcreeperz.com and use your stock springs. Entirely up to you.
Old Apr 25, 2005 | 07:31 PM
4DrMopar's Avatar
4DrMopar
so with a 3" front and 2" rear lift, I can just order shocks to fit a stock height 3/4 ton truck and shouldbe the right legnth etc?? that simple? damn this is way easier than my old cherokee
Old Apr 26, 2005 | 09:56 AM
Snafu's Avatar
Snafu
It may not be dead on, but it'll be close enough. Unless you're planning on doing some major off-road abuse, then you'll want to get a little more scientific with your shock lengths.
