Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Cheap Lifts
Old Feb 21, 2004 | 03:17 PM
DODGERAM99's Avatar
DODGERAM99
Default Cheap Lifts
I have 96 ram extended cab. I lifted the rear with 3"lifting blocks, but I am not sure what to use in the front coil springs....I have tried using the aluminum spacers, but the nose still saggs. I was also reading in a truck mag that there is a polyurethane coil seat and coilover spacer that was used to get an additional 2-3 inches. Can any one help
Old Feb 22, 2004 | 12:41 AM
356MAGNUM's Avatar
356MAGNUM
Default RE: Cheap Lifts
If i am thinking of the same thing that you calling the coil seat, its sometimes called a "leveling kit". All it does is raise the pocket of the spring to level out the 2" different between front and rear on the stock trucks. I also hope that the 3" blocks are kinda of wedged shape to align up the drive shaft angle, other wise you might be putting extra stress on the u-joint if you intend on having any serious fun. Also be aware that I have heard (magazine articles) of the block sometimes breaking due the the more rotational flexing of the axel.
Old Feb 25, 2004 | 09:26 PM
DODGERAM99's Avatar
DODGERAM99
hey Thanks For the important info. Actually the blocks I have at the moment are not slanted, but i was planning on changing them anyways. One other question .... how would you lift the front end other than using the leveling kit???
Old Feb 25, 2004 | 09:30 PM
cloud9ms's Avatar
cloud9ms
You can lift your front end using a new coil spring. That would ride better than a coil spacer anyway.
