Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
NEW LIGHTS
Old Apr 29, 2005 | 11:11 AM
Vader's Avatar
Vader
Default RE: NEW LIGHTS
Lookind awesome and I love the truck.
Old Apr 29, 2005 | 10:31 PM
cal_gecko's Avatar
cal_gecko
right on! looks good!!! I'd want to mount the switch in a more 'stock' looking location... perhaps run it up to somewhere on the dash and install a switch there... but I'm gonna check out those lights!! do they come with mounting hardware and stuff?
Old Apr 29, 2005 | 10:41 PM
cal_gecko's Avatar
cal_gecko
Just ordered a set.. I'll be putting them on my Ram as well
Old Apr 30, 2005 | 05:26 AM
ross944's Avatar
ross944
Sweet, post some pics of your install when they get there.
Old Apr 30, 2005 | 06:00 AM
|3|ackAc|D's Avatar
|3|ackAc|D
whats cool is that i heard that if your fogs are lower then your head lights that u can run them when ever you want but if htey are higher you can only use them off road or like not in the city
Old May 4, 2005 | 10:25 AM
HEMI 7's Avatar
HEMI 7
Ross Lights look great ..However thats a massive air intake you have.
Old May 4, 2005 | 10:32 AM
HEMI 7's Avatar
HEMI 7
Ross What did you use to mount it a bracket or dod they bolt to the frame in front of radiator? Thanks
Old May 4, 2005 | 12:02 PM
|3|ackAc|D's Avatar
|3|ackAc|D
the fogs have a like a brackin locking thing, and it just bolts on after you drill 2 holes. i also recomend you drill 2 smaller holes for the grounds
Old May 4, 2005 | 04:52 PM
ross944's Avatar
ross944
Mounted them directly onto the frame in front of the radiator. Make sure oyu use the right drill bit, tore up my wood drill bit...oops.
Heres a closer pic: drilled for the light mount and the grounding wire.
Old May 4, 2005 | 05:24 PM
ross944's Avatar
ross944
ORIGINAL: HEMI 7
4" intake tube, you should hear it at 3000rpm[sm=happybounce.gif]
