Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Lowering 4X4 Ram
Old Feb 24, 2004 | 01:49 AM
kemomn's Avatar
kemomn
Default Lowering 4X4 Ram
Does anyone know how to translate Dodge coil spring part numbers to find a shorter spring? I'm getting tired of having to throw things so da#@ high to get in the tailgate. My 01 4X4 Offroad is higher than a 1 ton ford at the tailgate!!
Old Feb 24, 2004 | 10:37 AM
Randy_W's Avatar
Randy_W
Default RE: Lowering 4X4 Ram
My '99 2500/4X4 is to tall at the gate to be usefull. I'm thinking about some shorter rear spring blocks to let mine down about 2"-3", it's a little tail high anyway!
Old Feb 25, 2004 | 05:01 PM
356MAGNUM's Avatar
356MAGNUM
There is a step that bolts to the bed side of the tailgate and flips around when you drop the gate. It does require screwing into the metal. I had a 72 blazer that had 12" lift with 39" tires. Being 5'7" even then i had to get a running start I think that JC Whitney has them.
Old Feb 25, 2004 | 09:33 PM
cloud9ms's Avatar
cloud9ms
If you want to raise the front, use new coils. If you want to lower the rear just get a 1 or 2" drop shackle/spring hanger. Either way will make your truck sit more level.
Old Feb 26, 2004 | 01:11 AM
kemomn's Avatar
kemomn
I'm thinking lower the whole truck. Back has 3" spacers between axle and spring, but then I figure it'll be nose high. So I'll have to drop the front to match.
Old Feb 26, 2004 | 01:17 AM
Randy_W's Avatar
Randy_W
My 2500HD has 4.75" spacers!!
