Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
slight ticking noise
Old May 6, 2005 | 11:54 PM
spicoli's Avatar
spicoli
Default slight ticking noise
Ihave an 04 1500 w/4.7ltr 28k mi. Recently Ive noticed a bit of a ticking sound in the engine, especially during start up. I use full synthetic oil every 6000 mi. Do not drive it hard at all. Always pampered. Anyone have this problem?Suggestions?
Old May 9, 2005 | 09:05 PM
rakram's Avatar
rakram
Default RE: slight ticking noise
This might be a clue to your problem. At the 15k checkup, my independent mechanic found an exhaust leak at the left manifold rear gasket. I am taking it into the dealer for warranty repair this week. My mechanic asked if I had recently heard any 'ticking' noise at start up. I must admit I did, but did not investigate it further. If this thread is still active, I will post my findings after the repairs.
Old May 9, 2005 | 09:21 PM
spicoli's Avatar
spicoli
Thanks RAKRAM. Ill look into that. I do wanna hear about yourfindings......
Old May 11, 2005 | 08:38 PM
rakram's Avatar
rakram
Reply to spicoli - ISTI is back from the Dealer (warranty repair) today. The exhaust manifold gasket was deemed OK, but the manifold mounting bolts were 'loose', especially rear left side. Technician found other bolts both sides not torqued to specs. Resolution was all bolts tightened to torque specs and cold start 'ticking' noise is no more.
Old May 26, 2005 | 01:56 AM
dodge94's Avatar
dodge94
my 94 Ram had the same problem until it got oil up on the rockers, then the oil pump went
Old May 26, 2005 | 05:23 AM
Redneck2345's Avatar
Redneck2345
What kind of oil pressure do you have when at idle? I know mine is low until I get on the gas some
