Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Bulletins 2002 Dodge RAM 1500 ½ Ton 4WD Pickup 4.7L
Old Mar 14, 2004 | 12:41 AM
356MAGNUM's Avatar
356MAGNUM
Default Bulletins 2002 Dodge RAM 1500 ½ Ton 4WD Pickup 4.7L
Bulletins for 2002 Dodge Truck RAM 1500 ½ Ton 4WD Pickup V8-287 4.7L SOHC VIN N SFI
Service Bulletins
TSB Number Issue Date TSB Title
22-003-03 JUN 03 Wheels/Tires/Driveline - Highway Speed Vibration
24-003-03 MAY 03 A/C - System Sealer Usage Prohibition
08-010-03 APR 03 Interior - Seat Belt Cinch Bar Service
18-008-03 MAR 03 Engine Controls - Co-Pilot Support/Cable Selection
08-002-03 JAN 03 A/C, Cooling System - Condenser Fan Inoperative
24-009-02 OCT 02 A/C - System Leak Detection
08-023-02 OCT 02 Audio System - Poor AM Band Reception
18-030-02 OCT 02 Engine Controls - Idle Undershoot When Stopped in Gear
14-001-02A OCT 02 Fuel System - Difficult Fuel Filler Cap Removal
23-039-02 SEP 02 Interior - Cup Holder Binds or is Slow To Open
23-035-02 AUG 02 Body - Accessory Grille Guard Cover Distortion
23-006-02A AUG 02 Bodies - Water Leaks from Interior Grab Handle
23-036-02 AUG 02 Windows/Glass - Rear Window Water leaks
19-003-02 APR 02 Power Steering - Hissing Sound
19-002-02 APR 02 Steering Column - Vertical Movement
23-015-02 APR 02 Outside Rearview Mirror - Glass Replacement
08-007-02 MAR 02 Keyless Entry - Programming Procedure
08-006-02 MAR 02 Front Door Speakers - Buzzing/Distortion
24-004-02 MAR 02 Instrument Panel Vents - Lack of Air Flow
22-001-02 MAR 02 Chrome Wheels - Care and Maintenance
23-012-02 FEB 02 Power Locks - Won’t Unlock Rear Doors
23-010-02 FEB 02 Headlamp - Snapping Sound on Rough Roads
23-002-02 JAN 02 Hood - Distortion/Low Spots
23-033-01 NOV 01 Seat Track - Rocking Or Chucking Movement
19-009-01 OCT 01 Driver Airbag - Trim Cover Service
08-017-01 SEP 01 Safety Systems - Vehicle Modifications/Repair
23-021-01 AUG 01 Body Panels - Overflush/Underflush Conditions
19-007-01 AUG 01 Power Steering - New Fluid Type
08-016-01 AUG 01 Radio - Caution: Locking Antenna Collar
21-006-01 JUN 01 A/T - Fluid Usage
08-010-01 MAY 01 Airbag/Clock Spring - Service
18-012-01 MAY 01 Generic Scan Tool - Reference Information
Old Mar 15, 2004 | 12:14 AM
beis's Avatar
beis
Default RE: Bulletins 2002 Dodge RAM 1500 ½ Ton 4WD Pickup 4.7L
hi, how do I access the details of each of those bulletins from TSB?
also, have you had any ball joint/tie rod/ sway bar link problems?
what did you do with the speaker rattle noise?
thanks,pbeis
