Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
frikkin seat belt chime HELP !
Old Mar 11, 2004 | 03:12 PM
pabs's Avatar
pabs
Default frikkin seat belt chime HELP !
i have an 04 hemi
there is an instruction in the manual to turn it off but it doenst work, the factory disable the turn off sequence (i checked with the dealer AND chrysler customer service)
the customer service rep at chrysler however did say the tech told him that it is simple a wire that need unplugged or cut under the sterring wheel
can anybody help ?
also what other forums are there for dodge, would like to try those too
thks !
(hmm went a post without mentioning dodgegirl...)
Old Mar 11, 2004 | 03:27 PM
Klute's Avatar
Klute
Default RE: frikkin seat belt chime HELP !
In the past with other vehicles I would simply unplug the buzzer/chime.
Usually it was mounted on the floorboard/firewall.
Open the door, track down the chime and unplug it.
I don't know if Dodge does the same thing or not, but it is worht a try.
Old Mar 11, 2004 | 03:51 PM
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
Hmmmm... that's not good, leaving us to go elsewhere. Most everyone here knows referring away from DF doesn't make The Lady in Red happy... LOL! Have you tried searching...? There's two other massive ones around, both are bigger then us (not for long if I have my way), they've been around a lot longer though. DT and DTW.
~Amanda
Old Mar 11, 2004 | 08:16 PM
gpzjack's Avatar
gpzjack
I just plug in my center passenger seatbelt and leave it there. Problem solved!
Old Mar 12, 2004 | 08:08 AM
IrvineDodgeGuy's Avatar
IrvineDodgeGuy
i had to turn my seatbelt chiming off too... that thing drove me crazy!! it says in the manual how to do it, it's really easy
Old Mar 12, 2004 | 11:43 AM
TwiztidRyda's Avatar
TwiztidRyda
In reply to IrvineDodgeGuy :
I couldn't find it in my manual. How did you do it?
Old Mar 12, 2004 | 03:30 PM
pabs's Avatar
pabs
its there in the manual just look
however the function has been disabled for the 04
re pluggin in the middle seatbelt that doesnt work for me as i like to use my belt most of the time
spoke to customer service and the techs told me that you cut or unplug a wire under the steering column and that its easy, let me know pls if anyone does it before me
if i do it first will certainly post which wire to cut/unplug
damn bell , i wear the neighbors dog is talking to me, in latin no less and he wants me to do bad bad things
Old Mar 12, 2004 | 03:44 PM
Deviousin10tions's Avatar
Deviousin10tions
Are you sure? My manual say's it can be done, but I haven't tried and the manual does say 2004 Dodge Ram
ORIGINAL: pabs
Old Mar 12, 2004 | 03:48 PM
pabs's Avatar
pabs
im sure, its in my manuel too but the factory disabled the feature for the 04 and didnt reprint the book
Old Mar 12, 2004 | 10:21 PM
TwiztidRyda
The owner's manual? If so what page?
